engine skip
Old 01-08-2010 | 01:42 PM
ringo's Avatar
what is the proper fuel pressure (psi)?
  #22
Old 01-08-2010 | 03:44 PM
TURBO 245's Avatar
Engine at idle fuel pressure regulator vac hose removed around 43 to 44 psi.
Engine at idle fuel pressure regulator vac connected around 36 to 37 psi.
Dan
  #23
Old 01-09-2010 | 01:50 PM
fredbyte's Avatar
Also try a new air filter.
  #24
Old 01-10-2010 | 09:27 AM
ringo's Avatar
thanks for the info.
replaced air filter.
  #25
Old 01-22-2010 | 12:31 PM
ringo's Avatar
my volvo 740 is now very sick. have checked fuel pressure and it seems fine with plenty of flow. however, when i had the fuel line off, turn ignition to "on", a good stream flowed, then stopped after 1-2 seconds. is this normal?
thanks for your help
tngreg
09-05-2022 08:27 PM
tr_car_nut
05-09-2008 09:30 AM
sbrownbw
09-23-2005 10:49 PM
