Engine surges when electric rad fan turns on
Old Jun 3, 2009 | 11:13 AM
brf0007's Avatar
Default Engine surges when electric rad fan turns on
I was just finished replacing an O2 sensor that had 225,000 miles on it, and the original ignition coil, and I was under the hood marveling at how smooth my engine was running. Then all of a sudden the electric fan kicked on, and the engine surged and threatened to die. It leveled off again a few seconds later and seemed to run fine.
This isn't a big deal, but I would like to know what might be causing this, so if anyone has any ideas how to fix this problem I would be very grateful for your advice. It charges fine according to my DV/OM, and I'm not really sure what else might be causing the issue. This poor car seems to have a lot of electrical gremlins, I have replaced almost all of the engine mounted sensors, as well as a number of other electrical components. So most everything electrical is new... or new to the car anyway. But I figure at some point I'm going to end up replacing everything and it will basically be a new car... hahaha.
Old Jun 3, 2009 | 01:12 PM
bubba240's Avatar
What year and model?
Do you see the battery voltage drop at the coil when it kicks on?
Old Jun 3, 2009 | 04:28 PM
brf0007's Avatar
Default RE: Engine Surges when electric rad fan turns on
Oh right, sorry. Its a 1993 940 Turbo Sedan. 250,000 miles. I haven't checked whether or not the voltage drops at the coil when it kicks on, lets assume it does drop, because as far as I can figure, it must be a drop in available power causing the engine to surge when the fan kicks on. So, assuming that it does drop, what is your diagnosis?
Old Jun 3, 2009 | 05:20 PM
bubba240's Avatar
I would start by cleaning both ends of your battery cables.
Old Jun 3, 2009 | 05:52 PM
brf0007's Avatar
Both the cables and the battery were recently replaced. as well as the plugs, plug wires, distributor, coil and o2 sensor.
Old Jun 4, 2009 | 07:23 AM
adub96's Avatar
It's a trap, RUN!
Old Jun 4, 2009 | 08:38 AM
tedv's Avatar
You say "surged" but I think you mean the opposite since it almost died... Anyway, I'd say this is normal to a point... That fan draws a lot of current and this affects the RPM momentarily until the computer kicks the idle back up.
Old Jun 4, 2009 | 11:33 AM
brf0007's Avatar
Originally Posted by adub96
It's a trap, RUN!
Its not a trap, its a Volvo. An old *** Volvo. One that has served me well for a long time and has sentimental value.
Old Jun 4, 2009 | 11:35 AM
brf0007's Avatar
Yes, I meant that it shudders, not surges. I was thinking that it was probably worn components in the fan that were drawing more current than normal as the fan turns on.
Old Jun 4, 2009 | 11:52 AM
brf0007's Avatar
Quick question, does anyone know what type/brand/viscosity of fluid to put in my differential?
Old Jun 4, 2009 | 03:32 PM
adub96's Avatar
75w90
Old Jun 4, 2009 | 03:59 PM
brf0007's Avatar
75w90
Thanks for the info.
Honestly, I don't think the car is trying to lure me in so that it can kill me with the fan or anything. Its just misunderstood. But next time it does some **** like that me and the car are going straight to the field be3hind my house and I'm putting a bullet right between its eyes. Once a Volvo gets a taste of human blood, its best to just put it down.
i.drive.a.jag
Sep 14, 2011 12:53 PM
kockyhardrockr
Aug 1, 2010 07:42 PM
wayne@06S60
May 24, 2010 03:55 PM
