Failed Emissions Question
Hi everyone,
First of all, I am a first-time poster on this message board. I love Volvo's - especially mine.
I own a 1988 740 GLE non-turbo. Recently, it failed its emission's inspection. Here are the stats:
HC (PPM)
15 mph MAX: 209 MEAS: 165
25 mph MAX: 194 MEAS: 169
CO (%)
15 mph MAX: 0.86 MEAS: 0.86
25 mph MAX: 0.76 MEAS: 0.86
NO (PPM)
15 mph MAX: 1791 MEAS: 2580
25 mph MAX: 1591 MEAS: 2473
The HC passed with flying colors. The CO barely failed. The real problem is the NO it seems. The one thing I did not do was get the car to the emissions inspection warm - it had been sitting for about 45 minutes before they tested it. However, when I lived in California, I went to a Volvo specialist who seemed to know exactly what to do to make my Volvo pass - and I do not remember what that was. So, I thought before I tried anything else I thought I would post on this board to see if anyone had any ideas.
I do not use premium gasoline. Will that help? Will it also help to replace the cat? I am not sold on this is as a solution because high NOx is the cause of high combustion temperature. Any help would be greatly appreciated.
Thanks,
Sandman
HC (PPM)
CO (%)
NO (PPM)
Thanks,
Sandman
exhaust leaks......I passed everything but the NO TEST....a smog dude told me exhaust leaks....I used the beige paste that you can smear on the joints through out the exhaust system....
cold exhaust
spread with a stick or latex glove and finger....
all connections where claps may be AND THE MUFFLER....
leave it for two hours and done....
drive to California and back to smog place...
finito
cold exhaust
finito
Assuming your timing is where it should be, 12 degrees BTDC, retard it to 6-8 BTDC...it'll pass. NOx is a result of higher than acceptable combustion temps; the usual places to check are bad catalytic converter and/or bad egr valve. It's quite possible the O2 is bad, people don't seem to get just how important they are...a bad O2 can cause the car to run rich, running rich screws your gas mileage and the extra fueling ruins your catalytic converter! And...leaks after the amm and before the tb can mess w/ things. But to pass, just retard the timing as mentioned. I had to do that every year on my 84 760T...works like a champ!
1988, 1990, 240, 740, 940, california, emissions, emmissions, fail, failed, hc, inspection, pass, ppm, volvo
