failed NOX emissions test
Old Jul 26, 2006 | 05:20 PM
bli745's Avatar
Default failed NOX emissions test
278,000
1988 745 Turbo (all stock)
at last state inspection, 2 yrs/25K ago, passed with ease (3.25 allowed - measured .08)
this time measured 5.99, need 3.25 or less to pass. Garage says CAT is most likely,
another thoughts why so much difference in my well maintained car?
other info
HC 2.25 allowed/measured 2.07
CO 23.74 allowed/measured 18.08
NOX 3.25 allowed/measured 5.99
CO2 656.31[]
Old Jul 26, 2006 | 05:57 PM
cbevis's Avatar
Default RE: failed NOX emissions test
to be high on only nitrous oxide isn't unusual and a new cat will probably fix it...or at least bring it to passing levels at which time you can pull the codes to see what the real problem is.
Old Jul 26, 2006 | 09:09 PM
Maybe Bad o2 sensor?
Old Jul 27, 2006 | 12:20 PM
cbevis's Avatar
wouldn't a bad o2 sensor just neglect to tell you your emissions were bad?
Old Jul 27, 2006 | 04:44 PM
wojeepster's Avatar
clean your flame trap.
Old Jul 27, 2006 | 06:57 PM
bli745's Avatar
Thanks, no flame trap on Turbo. Why we own Volvo's...durability dude: O2 sensor, Cat Convert
and Mitsu Turbo all have at least 160K on them. 278000 on odometer, next stop - 300K!
Old Jul 28, 2006 | 12:09 AM
No technical Flame trap but still has a Nipple that can clog and make the Reading off.
Old Jul 28, 2006 | 10:39 AM
bli745's Avatar
you are correct about that passage getting clogged, although it is OK now I
had to use a small drill bit to ream it out in the past. Thanks.
Old Jul 28, 2006 | 09:49 PM
wojeepster's Avatar
I am not real familiar with the turbos. Other vehicles use egr to recycle some of the exhaust gasses. This lowers combustion temperature and reduces NOX.
rexaroo
1998-2000 model year V70
Mar 12, 2015 06:59 AM
emkay488
Nov 16, 2010 12:53 PM
surnamex
Mar 25, 2009 04:49 PM
covolvo
Aug 21, 2007 08:10 AM
Apex
Mar 9, 2007 01:26 AM
