Fan Belt and Alternator
Old Feb 8, 2007 | 11:33 PM
sirjinx's Avatar
Default Fan Belt and Alternator
Hello,
I have a 93' 940 turbo and i was wondering how hard is it to change the fan and alternator belts myself. I would be doing this and anything close to this for the first time, I am a college student and I am trying to save as much money as possible. Any help will be greatly appreicated. Also which belt goes on first if its a easy job?
Thanks in advance,
Jay D.
Old Feb 9, 2007 | 12:11 AM
Default RE: Fan Belt and Alternator
It is pretty easy.
One 13mm nut for each comp. Then a 10mm screw to adjust belt tension.
Loosen the Comp. you want to remove the belts from. Then remove the belts one at a time putting them in an order to install the new belts in reverse order.
Old Feb 9, 2007 | 12:53 AM
sirjinx's Avatar
Thank you very much........... I think I will try to do it myself instead of paying someone to do it.
Jay D.
Old Feb 9, 2007 | 12:56 AM
sirjinx's Avatar
One more thing just so that I correct in my statements, which belts go around the alternator I know has to be the alternator belt and the other is what?
Old Feb 10, 2007 | 09:59 AM
Some just go around the alt. and crank.
Some go around the Alt.,water pump and crank.
ingydrummer
Feb 28, 2020 03:33 PM
norasaint
Sep 20, 2012 12:53 AM
guest01
Nov 5, 2011 10:11 PM
elouadj
Jun 25, 2008 07:00 PM
volvoforums53
Oct 4, 2006 10:52 PM
