a few light questions...
Old Jul 27, 2012 | 10:34 AM
jayson44's Avatar
Default a few light questions...
my passenger headlight has been going out every now and then. the brights still work, but the dim goes out. sometimes it comes back on. sometimes, I can wiggle the wiring at the back of the lamp and get it to come back on...
is this the wiring? or the bulb?
also...my dole-light is out in the rear (always has been) and I want to replace it. not sure how to get the plastic cover off to get at the bulb. any suggestions?
J.
Old Jul 28, 2012 | 12:52 AM
change the bulb, its easy and cheap. if the new one still does it, then its the wiring.
Old Jul 30, 2012 | 09:01 AM
jayson44's Avatar
any ideas on how to get at the rear dole-light bulb?
J.
Old Jul 30, 2012 | 11:58 AM
you're talking about the 3rd brake light? afaik, the cover unsnaps, but ours hasn't gone bad in so long, I don't remember. old plastic gets brittle, which makes it challenging
Old Jul 30, 2012 | 12:50 PM
jayson44's Avatar
yeah...I was trying to unsnap it, unhook it, unscrew it...whatever, but I couldn't figure it out. I guess I'll keep messing with it and see if I can get it to let go.
J.
Old Jul 30, 2012 | 12:56 PM
worse case if a tab breaks, I've been known to re-install those with a bit of clear RTV (Silicone aquarium sealant), as its fairly easy to remove later...
Phil 850
Jul 25, 2012 10:01 PM
theantidote
Aug 28, 2007 07:31 PM
KaReN 850
Aug 14, 2005 08:32 PM
Gbenzx
May 30, 2005 01:43 AM
on_ice
Mar 13, 2005 08:48 PM
