Front end/steering wheel vibration
Old Dec 9, 2009 | 09:49 PM
300K740's Avatar
Default Front end/steering wheel vibration
My 89 740 GL has been doing this for a little while now. At higher speeds when I press on the brakes the steering wheel will shutter back and forth about an 10-20 degrees in either direction.
I've replaced my sway bar links since they were worn, the car has 306k miles on it right now. I'm looking more towards the brakes to be the cause. When I brake at slower speeds (<5 mph) I can feel it grab more at different rotations of the tire than others. I'm thinking maybe a bent rotor?
Just looking to see if anyone else has run into this. I have never seen this on a car before where the brakes could affect the steering even with slightly warped rotors.
Old Dec 9, 2009 | 10:18 PM
john1990's Avatar
rotors need turned down, and check calipers to make sure their releasing correct
Old Dec 10, 2009 | 12:36 AM
Typhoon's Avatar
Agree with above, but at that mileage, might need new rotors.
Also look at tie rod ends, they will cause this issue if they are original and worn. They're cheap to replace and easy to do when teh rotors are being done.
Regards, Andrew.
Old Dec 10, 2009 | 09:13 AM
300K740's Avatar
Thanks, that's what I was thinking, just wanted to get a few opinions before I bought parts.
RPMCanes
Sep 10, 2016 09:58 AM
casualfc
Oct 6, 2008 09:34 AM
ocean238
Apr 17, 2008 06:20 PM
DaveNY
Aug 2, 2005 10:03 PM
JimKW
Jun 14, 2005 06:38 PM
