fuel filter changing instructions
Old Nov 17, 2008 | 02:14 PM
vipul_vips's Avatar
Default fuel filter changing instructions
I am trying to change the fuel filter in my 1991 740 SW (non-Turbo)
I am following chilton manul.
a. Disabled fuel filter fuse.
b. Located the fuel filter
However I am not able to get the fuel filter removed from the piping. The bolt seems to be dead tight and wd20 does not seem to work.
I am assuming someone has better step by step instructions on how to do this with pictures.
Can you please post a picture or the manual on how to do this step-by-step?
Old Nov 19, 2008 | 10:19 AM
wojeepster's Avatar
Default RE: fuel filter changing instructions
If you look you will see that fuel filter has hex on both sides under banjo fitting. They are different sizes on each end. Some gorilla tightened mine so tight I thought I would never get it off. With two wrenches you will be able to. I don't bother with the fuse thing, not that much fuel comes out anyway.....
Ahmed
Jan 29, 2010 01:32 PM
spankey
Mar 14, 2009 11:06 AM
nonsense619
Feb 9, 2009 12:20 AM
aruizdelhoyo
Jan 22, 2009 04:46 PM
spioana007
Jun 30, 2008 11:34 AM
