Fuel Millage?
Old Jun 21, 2007 | 04:12 PM
funnyguy44444's Avatar
Default Fuel Millage?
I have an '82 244 GL. I recently began to get very poor fuel millage. My first thought was to replace the air filter which i did. That made it a little better but it still is relatively poor. I thought that there might be a leak in the fuel line somewhere because i just cant seem to keep gas in the car. I checked for leaks and there doesn't appear to be any. My next move is going to be to replace the fuel filter. Does anyone have any ideas what else to do or how to check for leaks in the fuel system more thoroughly? Any ideas would be great.
Old Jun 23, 2007 | 02:31 AM
pznuttz's Avatar
Default RE: Fuel Millage?
If your car has CIS-K-Jetronic Fuel Injection it could be a bad fuel pump check valve on the fuel pump .or a bad cold start injector that leaks . u have any other issues such as O/D on trans? not engaging?
Old Jun 23, 2007 | 04:40 PM
Nope OD works great. I do have the CIS-K-Jetronic fuel injection. I'll look at the fuel pump. How would i test that to see if its the problem? I'll check the cold start injector too. Thanks for the tips.
Old Jun 24, 2007 | 05:03 PM
pznuttz's Avatar
what about your oxygen or O2 sensor ? My 240 turbo gas mileage improved significantly after replacing it and driveability improved
Old Jun 24, 2007 | 09:25 PM
Yea i've been thinking that myself. It could definately use a replacement. I think i'll go pick up one tomorow. Thanks for the advice.
Old Jun 25, 2007 | 10:22 AM
nactall's Avatar
do you smell gas when you drive your car? just general up keep can help out alot on the milage, regular oil changes, plugs, wires, defently look into the o2 sensor, even the tire pressure effects the milage
smithnr
Apr 8, 2013 04:56 PM
tonyt
Oct 14, 2011 06:36 PM
the_happy_driver
Jun 26, 2008 12:47 AM
chaniewski
Nov 13, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
