fuel pressure........ and speed sensor
Hi all,
I've got a '90 wagon that, while it runs great, is inconsistent in starting: sometimes it starts with a touch, sometimes takes 2-3 cranks. My shiny new Bentley manual leads me to think:
- speed sensor;
- fuel pressure regulator (letting residual pressure drop, resulting in dry injectors).
Fuel pressure: it's clear that, in order to work on 240s, you gotta be able to measure fuel pressure. Do I need a special fuel pressure gauge, or will the universal one at the local chain store work? What is the preferred method of relieving pressure on the system before attaching the gauge?
Speed sensor: I've read horror stories of breaking the sensor mounting bracket during removal, necessitating pulling the tranny. Any advice on how to avoid this?
- speed sensor;
RE: fuel pressure........ and speed sensor
For the fuel pressure check and see if you have a little nipple almost like a Valve stem on a tire on the metal part of the rail like between #1 and #2 injector. If you do a universal one will work.
If not you need a special setup.
SOAK with PB BLASTER.
I have heard the stories as well. I have never broke one though.
The Volvo fuel line threads (14mm by 1.5mm pitch) are very close to the National Pipe Thread 3/8 by 18 tpi. Go to a good plumbing supply store with a rack of brass NPT fittings and buy:
[ul][*]Male 3/8 NPT with barb fitting on the end[*]Female 3/8 NPT with barb fitting on the end[*]"T" insert[*]Hose to fit and six worm clamps to fit the hose.[*]Male 1/8 NPT with barb fitting on the end [/ul]
Assemble so that the male and female 3/8 fittings go into the fuel line fittings (use teflon tape to fill any thread gaps and don't strip any threads) with the T in between, connected by hose and secured by hose clamps. Add the extender hose to the side of the T, terminating in the male 1/8 into which your fuel pressure tester fits. If you want to be clever, you can use a terminating schraeder valve at the end too.
Only thread this onto the fuel rail by hand, just enough to seal and get a reading on a pressure valve.
But to tell the truth I think you're paying interest on borrowed troubles .
montysano, Jonesg is tellilg you how to make an adaptor to install a pressure check. Write down what he told you to get, go to PLUMBING SUPPLY STORE ( not home depot). The parts will be brass 3/8 female threads on one end, hosebarb on the other for two of them (used to install ice maker). The other will be a brass "T". Disconect fuel line at the rail and screw on female threads hand tight only, dont strip your rail or fuel line, the hose barbs will be facing towards each other. Cut a small piece of hose for each barb and clamp on, on each end of these install "T" and clamp. Cut 3rd hose as long as you need to install pressure gage and see it easily. Hope this sheds some light. This is real easy to do.
I think when anyone has problems pulling the speed sensor they might have done it wrong, levering it causes the problem, just twist it and it will come straight out.
Levering can't work because its inserted too deep, but the inserted portion is round so it can be twisted to loosen, by hand.
If it won't run on ether then its not getting spark. If you don't have a timing light just use an old plug and backtrack to the coil wire, if it sparks then check inside the dist cap.
If no spark at coil wire check the low voltage side for signal. Clean connectors, try again.
If no dice....I think it gets the signal from the flywheel sensor via the computer.
You have a 90 wagon, what type? is it a 740?
Is the ignition rex regina or ?
Is your coil a cylinder shape or a square type (regina).
Try reading through this,
http://www.brickboard.com/FAQ/700-90...alIgnition.htm
ORIGINAL: gforce
Ummm..... yeah, I got that part. It was the "paying interest on borrowed troubles" part; what does that mean?
MntnDewMan
04-03-2024 04:05 PM
submit
03-27-2021 05:44 PM
