fuel pump fuses?
Old Jun 29, 2006 | 03:50 PM
swsail's Avatar
Default fuel pump fuses?
Was going to change out my canister fuel filter. Its recommended to remove fuel pum fuses, star engine and run till it dies to bleed pressure before changing filter. I removed both in-tank pump & main pump fuses and engine still runs fine after 10 minutes with ability to run smooth & rev up. What's up?? According to the color coded fuse tags the correct wires are connected to those fuses??
Old Jun 29, 2006 | 08:50 PM
Default RE: fuel pump fuses?
That really doesn't Cut the fuel pump off. If you really want to do that then you will need to unplug it.
I never do that I loosen the line slowly and let the pressure bleed off.
Or push in the Valve on the fuel rail and bleed it off that way.
Old Jun 30, 2006 | 03:56 PM
swsail's Avatar
Thanks for the input Tech, I'll try your valve suggestion, but I'm confused about your fuse explaination. So Volvo installs fuses to interrupt circuits, but the circuits stay live whether or not the fuses are in?
sw
Old Jul 1, 2006 | 09:57 AM
It is like a Back up fuse.
You didn't specify exactly which car you have but you could also remove the relay and let it die.
spidersilva
Aug 17, 2011 07:23 PM
vegedge
May 31, 2007 10:46 AM
BigBoi4Lyph
May 24, 2005 12:58 AM
KNIN
Apr 27, 2005 01:37 AM
