Fuel pump relay
Old Apr 10, 2014 | 07:29 PM
Samilton's Avatar
Default Fuel pump relay
Is there anyway to fix a fuel pump relay? I think mine is broken, only one of the internal relays close when i try to start it.
thanks
Old Apr 10, 2014 | 11:24 PM
sometimes you can resolder it but other times its just worn out and should be replaced.
the one relay should close when you turn on the ignition switch, this powers the ECU and stuff. the other relay only closes for about 1 second when you turn the ignition on, then opens again, and closes when the engine is actually turning over, this 2nd relay is what actually powers the fuel pumps.
you didn't say what year/model car this was for.
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
madhatter
Dec 7, 2005 06:00 PM
crazypixie
Jan 22, 2005 01:01 AM
