Fuel pump relay ticking when going over bumps...
1986 240 DL wagon
Replaced:
in-tank fuel pump
fuel filter
fuel pump relay
problem:
3 days drove fine...better mpg.....but every time I would go over a bump, small or big, the fuel pump relay would make a clicking sound followed by no fuel delivery for about 3 to 5 seconds...after it would continue normal...WHAT THE HELLL...
I went out of a shopping mall and the curb where the water runs off was a little deep....click click went the fuel pump relay and I had to push all the way home...has not started since...
Replaced:
in-tank fuel pump
fuel filter
fuel pump relay
problem:
i found my own problem...
I did not tighten the positive cable on the battery....the smaller red cable that makes contact when you (not high) tighten the battery terminal connection....
Pretty lame...
Every time i would go over a bump the red cable would stop making contact and thus my fuel cut off....dam....three days loss of work....
Pretty lame...
02VolvoS40
02-12-2012 06:10 PM
ByronTech
04-04-2011 05:31 PM
