Fuel Sending Unit
Old Jan 7, 2012 | 04:20 PM
mtc28's Avatar
Default Fuel Sending Unit
Mechanic says the fuel pump in my 940 non-turbo needs to be replaced along with the sending unit. Can we get by without replacing the sending unit which is over 400bux from the dealer?
Old Jan 7, 2012 | 05:28 PM
swiftjustice44's Avatar
Sure you can. If your mechanic isn't comfortable doing it, find another mechanic...seriously. The sedan has the access panel in the trunk while wagon's have it in the cargo area. The entire assembly comes out, swap pumps and back it goes. Chilton's give a labor estimate of 1.7 hours. The shop should quote you 2 hours to cover themselves. Perfectly acceptable as labor guides always presume everything goes smoothly and it never does. The tank does not need to be drained as the access is done with the tank on the car. Again, if the mechanic has other plans...consider going elsewhere.
mk4rida
Jul 9, 2010 01:05 PM
petes99xc
Jul 4, 2010 08:13 AM
manwithabird
Sep 21, 2009 08:28 AM
worldbound4now
Jul 18, 2009 09:09 AM
cg23cpo
Jun 30, 2007 06:02 PM
