Fuel tank
Old May 10, 2011 | 03:37 PM
bledsoe1's Avatar
Default Fuel tank
I have a 1990, 240 DL that I recently purchased and it has some holes in the gas tank. I loosened it but do not know how the filler tube comes loose.
Old May 11, 2011 | 07:03 AM
act1292's Avatar
There is a clamp that is accessible (with difficulty) from under the car that attaches the metal filler hose to the tank. If you remove the tank, the tank can be lowered and the filler tube will slide out. I did this once and had to use a long extension on a socket wrench to loosen the clamp. I may have had to use a flex drive on it as well.
Good luck.
Old May 12, 2011 | 12:08 PM
bledsoe1's Avatar
Default Gas Tank
Thanks for the advice. I did see the clamp, and your help is appreciated.
AnEskimo
Oct 7, 2010 07:28 AM
boxermike7
Jul 17, 2010 03:47 AM
skyrider20
Nov 29, 2008 07:01 PM
the_happy_driver
Jun 26, 2008 12:47 AM
ReneVersteeg
Apr 4, 2005 08:58 PM
