240 Wagon tailgate strut removal
Old May 11, 2011 | 04:34 PM
awolkoff's Avatar
Default 240 Wagon tailgate strut removal
Hi,
I purchased replacement tailgate struts from ipd. They have a circular eye on one end and are threaded on the other. The threaded end is clearly meant to screw into the brass "ball" that is attached to a socket on the door frame. The problem is I can't seem to get the old strut unscrewed from the brass ball.
Tips/suggestions? Thanks in advance.
Old May 11, 2011 | 06:26 PM
Burn Stains's Avatar
Get PB Blaster now. Millions of other uses in addition to your problem.
Old May 13, 2011 | 11:29 AM
awolkoff's Avatar
Solved.
Even with a vice grip and liquid wrench, the shaft of the strut would not unscrew from the brass socket. I ended up popping the strut/socket off the car. I held the shaft of the strut with a vice grip and used a pipe wrench on the socket to twist it off. Once came off right away, the other required more cursing and effort but eventually it too came off.
Old May 13, 2011 | 11:45 AM
phew. I am happy to say, the 740/940 struts are *MUCH* easier than this. pop a spring clip off the socket, and pop the socket off the ball which stays on the car. snap on new strut, snap on spring clips (they come with the struts). done.
the 850 is a little trickier, the struts are hidden behind the plastic above the rear side windows, so you remove the C pillar and top plastic trim, then do about what I described above.
drenman
2001-2013 model year V70
Jun 26, 2015 11:15 AM
gabanja05
Jun 8, 2011 06:42 PM
240classic
May 28, 2011 06:02 PM
briang2ad
Oct 22, 2008 10:49 PM
ludeless
Dec 17, 2005 07:14 PM
