Got it running! Thanks for the advice!
Old Dec 26, 2006 | 01:53 AM
newell21's Avatar
Default Got it running! Thanks for the advice!
Ok so now i got the shifting thing fixed, i went out early this morning like around 7:30am to go to the store. I got in my 89 740 turbo and started the car, went to the store and came back! then about 2 hours later i went back out and it would not start. It turns over and once and a while it will catch and sputter for a little then shut off and not start again! any thoughts???
Old Dec 26, 2006 | 10:33 PM
Default RE: Now it wont start! AHHHHH!!
Bad fuel pump relay or maybe fuel pump.
Old Dec 26, 2006 | 11:07 PM
newell21's Avatar
Ok i will check the relay first, but how do you know if it is bad??
Old Dec 26, 2006 | 11:09 PM
Find it and open it up and inspect the solder joints.
Old Dec 26, 2006 | 11:10 PM
newell21's Avatar
Ok will do....thanks!
Old Dec 29, 2006 | 02:28 AM
newell21's Avatar
Ok i took it out, here are some pics. The one side of the relay on the solder has like this gunky stuff on them is this a bad relay??
Old Dec 29, 2006 | 11:56 PM
Sorry pic to far away.
Look good and see if you see cracks around where the Wires/probes come through the circuit board.
Old Jan 8, 2007 | 03:08 AM
newell21's Avatar
Default RE: Picture of Fuel Pump Relay, is it bad??
Ok well its been a couple of days that i could get back on here! The relay turned out to be ok, i replaced the fuel filter instead and replaced the fuel lines. It started right up yaaaaaaay!!!! I just wanted to say thanks for all of the sugestions and help! This site RULE'S!!
Old Jan 8, 2007 | 08:44 PM
Glad the site helped you!!
Jeffers
Nov 21, 2012 06:50 PM
justjeff
Jun 20, 2009 07:49 AM
RED MOFO
Dec 26, 2008 12:08 AM
slance66
Feb 4, 2008 02:28 PM
Ginger
Dec 24, 2004 08:49 PM
