Halogen?
Old Apr 25, 2006 | 02:33 AM
tupapison's Avatar
Default Halogen?
I would like to put halogen(or xenon? not sure which one they are) lights in my car, i already have HID lights and i would like to put white lights, like the one's in the pic, but like those ones, more like i drill a hole in my bumper for them to go in they are from a 740, but yeah, any sites?
Old Apr 25, 2006 | 08:34 PM
Default RE: Halogen?
Did you look at your bumper and see if it already has a Hole? It might.
The stock lights are Hella's and are pretty pricey.
I would search for a set you like the looks of and buy them.
Old Apr 25, 2006 | 08:42 PM
tupapison's Avatar
Thanks Tech, my car has a hole (triangular one) on each side, but on th left side of the car is the towing thing, so i doubt a light will fit there.....but i dont know where to look for the Hella's, and would they be white or yellow? i dont want yellow lights
Old Apr 25, 2006 | 09:33 PM
They came either way.
Look up under the bumper for a hole going into the metal part of the bracket itself.
Not on the front of the lower part of the bumper.
If you have the Hole you will have to put the nut on from under the car on the Bracket itself.
Old Apr 25, 2006 | 09:42 PM
tupapison's Avatar
what bracket? im talking about that i think, the hole is under the bumper, on one side there is a black thing that i can remove so i can put a light there, but on the other theres the hook so people can pull my car whenever i get stuck. Does this help? they are where the arrows are pointing, under that bumper
Would these fit?
http://www.ipdusa.com/ProductsCat.as...329&RootID=629
Or they are gonna be installed like the ones in the picture of the 740 i posted ?
What about these?
http://www.ipdusa.com/ProductsCat.as...541&RootID=629
Can the hook for towing be removed? like unscrewing it or not?
Old Apr 25, 2006 | 09:54 PM
Ok I know it isn't a Volvo but look how mine are mounted.
Some of the Volvo's mounted in the holes you speak of and some mounted like mine.
You might have holes in yours like mine does.
[IMG]local://upfiles/853/104AD906CD404FC6845A040579238E73.jpg[/IMG]
[IMG]local://upfiles/853/BC90238DB70A4699A16D91F9645930AF.jpg[/IMG]
Old Apr 25, 2006 | 09:57 PM
tupapison's Avatar
Well that looks good, i guess i could put them like that, because finding the right size for the hole might be hard,
Would these fit?
Old Apr 25, 2006 | 10:01 PM
They look like they install like mine.
The ones on the pic you posted looks like they mount like mine as well.
If they mounted in the holes you wouldn't see the sides of the lights.
Old Apr 25, 2006 | 10:10 PM
tupapison's Avatar
but those ones would actually fit in the holes? im sure they wont fit because the hook for towing is there, can it be taken off? what do you mean by "you wont see the side of the lights" if i mount them in the holes i think they would look better
Old Apr 25, 2006 | 10:33 PM
Yes it can come off.
If you put them in the holes they will sit almost all the way in the holes.
Old Apr 25, 2006 | 10:53 PM
Would kind of look like the ones on this car if you put then in the holes.
Old Apr 25, 2006 | 11:13 PM
tupapison's Avatar
is that the normal volvo bumper? because it sure doesnt look like it, and the ones from IPD will fit in those holes?
Old Apr 25, 2006 | 11:47 PM
It is not the stock bumper but made by Volvo.
They should fit but maybe be smaller.
Old Apr 25, 2006 | 11:53 PM
tupapison's Avatar
so the ones from IPD may NOT fit in the holes? well i can take the measurements from the holes and compare them to the IPD ones
Old Apr 26, 2006 | 12:00 AM
The IPD ones might be smaller.
Old Apr 26, 2006 | 12:29 AM
tupapison's Avatar
where can i get a pair that will fit exactly?
Old Apr 26, 2006 | 12:34 AM
  #17
Find a set of Hella's
Check a salvage yard near you.
Old Apr 26, 2006 | 12:35 AM
  #18
tupapison's Avatar
salvage yards are not the same as in the states, here they suck big time, Im talking on the internet, any ideas?
Old Apr 26, 2006 | 12:43 AM
  #19
http://www.autoanything.com/lights/20A50136A1.aspx
Check here or you will have to find a used set.
I don't think they still sell the exact size ones anymore.
Old Apr 26, 2006 | 12:46 AM
  #20
tupapison's Avatar
Hmmm i see, would these fit? i think so, look at the dimensions
http://www.autoanything.com/lights/69A1330A0A0.aspx
