Hard starting when warm
The car in question is a 1985 240. When cold the car fires up within 2-3 seconds of cranking. But if I get it up to operating temp and shut it off and go in the store and come back to try and start it, it takes about 8-10 seconds for it to fire. A small inconvenience but one that I want fixed ASAP. Any help would be appreciated.
try this next time when its doing this. switch it off, then back to II (Run) wait a sec, turn it off and back to II, wait a sec THEN III (Start)... when you turn it to II, the fuel pump runs for about a second. many people just turn it straight from off to III and that doesn't give the fuel pump a chance to develop fuel pressure.
other possible causes... when was the last time the car got a 'tuneup' ? (New plugs, distributor cap and rotor, plug wires, air cleaner, fuel filter, ...)
a marginal coolant temp sensor could be throwing off the warm start timing.
you might be misremembering. turning the key to II does not cause the fuel pumps to run for a split second (for either an ‘87 or ‘88 DL)
