hatch panel repair
Old Jun 2, 2010 | 08:50 AM
Tubaczar's Avatar
Default hatch panel repair
Is there a better way to attach panel to hatch on a 1991 740 SW?Or change the panel for that matter?
Old Jun 5, 2010 | 09:32 AM
tedv's Avatar
Yes...
Old Jun 6, 2010 | 02:36 PM
Tubaczar's Avatar
Default rear hatch repair
need after market or self engineered way to better secure rear panel on 1991 sw.thanks in advance, Tubaczar
Old Jun 6, 2010 | 02:42 PM
Tubaczar's Avatar
Specific model is 740 SW and it does already have the metal brackets for the plastic pins to slide into.Oh and that damn rear light cover, Jeez.
Old Jun 8, 2010 | 09:55 AM
tedv's Avatar
You have TOP and BOTTOM attachments on the panel. The top has plastic clips which slide into the gate (METAL), and on the panel side they fit into the plastic which is usually broken. IPD sells a kit, metal clips which attach over the broken plastic into whict then the clips fit-it works ok... The botom of the panel has plastic 'ears' which if broken are hard to repair, and in such case you may drive a couple of screws to hold the bottom in place-ugly but effective... OR, get a new panel from a junkyard.
The light cover should stay on once the panel is attached securely... There are clips on it and it goes on just so, so don't force it-these clips rarely break...
rmmagow
Jun 1, 2011 10:58 PM
jrcochranusa
Feb 19, 2010 02:30 PM
tuco23
Dec 15, 2008 03:40 PM
RTrex001
Aug 24, 2008 10:21 AM
rp850
Oct 22, 2006 03:34 AM
