Head gasket job 94 940/parts recommendations? IPD cam is in there, other maintenance?
Old May 11, 2017 | 09:08 AM
drenman's Avatar
Default Head gasket job 94 940/parts recommendations? IPD cam is in there, other maintenance?
Title kinda says it all. I'm taking the head of my Bosch '94 940 redblock.
I pulled the plugs yesterday, somewhere I remember an "indicator" being a "greenish tint" to the plugs. How about a GREENISH FLUID??? It's cooked.
I'm hoping I can machine it flat, but are there parts from FCP most likely, they're ten mins away, and or IPD, or normal parts suppliers anyone would recommend?
Any other maintenance I can do beside draining the coolant, and I've heard there's a drain plug for the block by the oil filer on the left of the car, but I can't seem to find it. Pump for the trans coolant line is there...
Also sensors. I know my temp sending unit is fried. Should I do a water temp sensor just to be safe? I'll replace the thermostat, and all gaskets.
Also a "how to" link, and I'll troll the archives here as well as online.
Thanks in advance. Header bolts all came off like a breeze. I'm always amazed at how well PB Blaster works. It's like the "Oxy-Clean" of the automotive world.
Old May 11, 2017 | 09:11 AM
drenman's Avatar
https://www.fcpeuro.com/products/vol...-victor-270689
Thinking this and a thermostat & plugs...
Old May 12, 2017 | 07:57 AM
modifierwong's Avatar
I personally used the Goetze head gasket set. However, I was not too happy with the valve seals, so I'd recommend Victor Reinz seals that I ended up using.
As for some other tips, ensure your head is flat...whether you want to take it to a machine shop or do it yourself. I ended wrapping a piece of laminated MDF in sandpaper to do my own DIY resurfacing.
For tightening head bolts, clean your threads with a chaser, buy an angle gauge, and give your cleaned bolts a light coat of oil. This is the worst step to cheap out on because you definitely don't want to snap a head bolt. Go ahead and reuse your bolts.
Knock on wood, I've made it 10,000 Kms, since my rebuild and it's still running strong.
Old May 12, 2017 | 11:49 AM
drenman's Avatar
I'm replacing the bolts, and block and head will be flat or replaced, if too out of spec/machinable. In this case the "Machine" will be 3m paper on glass on marble block/flat and poilshed beyond any feeler gauge I've got.
I do the same thing to rehabilitate old Stanley/Record Bailey planes for woodworking.
ycartf
Aug 26, 2010 11:05 AM
850_Volvo_Dan
Mar 6, 2009 12:39 AM
autolampsplus
Sep 27, 2008 01:41 PM
Carbuff
May 19, 2005 04:44 PM
