Head Replacement
Old Mar 14, 2006 | 12:18 AM
rotarykid7's Avatar
Default Head Replacement
Quick question
i got a new head for my 93 940 8v, I'm not sure if i should use permatex on the head gasket or not? both surfaces should be flat since its a new head and the top of the block doesn't warp, right? do you guys recommend permatex just in case?
thanks
Old Mar 14, 2006 | 12:34 AM
Default RE: Head Replacement
DO NOT USE ANY SEALERS ON THE HEADGASKET!!
Just make sure you follow the proper Torque and Angle specs and you will be fine.
Old Mar 14, 2006 | 01:19 AM
rotarykid7's Avatar
thanks for the info
just wondering...can the permatex cause a coolant leak?
Old Mar 14, 2006 | 09:28 PM
A little more info please.
Where did you use it?
Old Mar 17, 2006 | 12:53 PM
rotarykid7's Avatar
i used permatex on the head gasket on the old head, before i knew not too.
i got the new head bolted down and everything is working, except i have a oil pressure light on now. i checked the sensors on the head and there hooked up, and there is no leak from the valve cover or the front and rear cam seals.
any ideas?
Old Mar 17, 2006 | 08:24 PM
rotarykid7's Avatar
never mind
i moved the wire around to the sending unit and the light went out
thanks for the help
car is running like new!
Old Mar 17, 2006 | 09:23 PM
Congrats glad all is good now.
Old Mar 17, 2006 | 11:43 PM
rotarykid7's Avatar
Thanks again for the help!
Not a bad job at all, could have been much worse!
Old Mar 17, 2006 | 11:47 PM
Yes I know they go pretty smooth.
boxpin
Dec 20, 2015 05:08 AM
autolampsplus
Sep 27, 2008 01:41 PM
uniquemicro
Mar 9, 2008 04:33 PM
ENDEE666
Nov 8, 2006 08:29 PM
johnnybravo
Engine & Internal
Apr 5, 2006 12:52 AM
