headlights, dash lights, warning lights flicker slightly
Old Aug 22, 2011 | 07:50 PM
zloetakoe's Avatar
Default headlights, dash lights, warning lights flicker slightly
Kind of a weird issue I'm having. 88, 240. The headlights and any other light (bright indicator/brake failure/bulb failure/headlights/dash lights) all flicker slightly. Only the brake failure (brakes are fine, the light is just on) and the bulb failure light are on, and I just changed the alternator about 4-5 months ago. The headlights flicker, but this is barely noticeable. All the lights flicker in the same rhythm. Any ideas?
Old Aug 25, 2011 | 12:58 PM
labelsdc's Avatar
same happened to me about a year ago. I heard starter, alternator, etc.. All of a sudden, the car died on the highway. Come to find out the battery was bad. Got it replaced with a high power battery and all was right with the world. Hope that helps.
Old Aug 27, 2011 | 11:22 AM
zloetakoe's Avatar
Hey, that's a great start. I'll go get the battery checked at some point. Did you have a hard time with starts, or any other problems, or did it just die on the highway?
I'm wondering if a bad battery will cause any other symptoms, like car not running well immediately after starting it, but runs fine 3-5 minutes later (already changed the engine temperature sensor). When it's running rough right after starting, the car doesn't shifts abnormally. Shift kinda rough and takes longer for the car to decide to shift, but goes back to normal after those 3-5 minutes. For instance instead of shifting as soon as the car gets to 15 mph to 2nd gear, it will shift 2-3 seconds after getting up to that 15 mph shifting speed with moderate acceleration. It would be nice if a new batter would clear all that up, hopefully someone has experienced something like this.
Old Aug 27, 2011 | 01:34 PM
darkdelta's Avatar
First thing that came to mind is a grounding problem. Check grounds between battery and chassis. Battery cables to the terminals are also suspect. Try the easy stuff first.
Good Luck
Old Aug 27, 2011 | 01:37 PM
zloetakoe's Avatar
Good Luck
Will do, thanks.
Old Aug 27, 2011 | 02:06 PM
brickrunner's Avatar
Good Luck
X2 seems like a grounding problem to me too.
ijourneaux
Aug 26, 2013 01:09 AM
sgplayer69
Apr 17, 2011 12:51 PM
VDriver24093
Feb 21, 2011 04:35 PM
hammer1234
Jun 6, 2010 12:03 PM
sgram
Jun 6, 2009 04:39 AM
