headliner board help
Old Nov 29, 2009 | 01:23 PM
john1990's Avatar
Default headliner board help
I purchased a new headliner, glued up both. When almost done realized the material was short. now the board is ruined. at least till the liner falls off in 20 years. any help or suggestions would be helpful. 90 740gl wagon w/sunroof same info given JC Whitney.
Old Nov 30, 2009 | 02:24 AM
Typhoon's Avatar
Board is not ruined. Is teh edge that is short a nice, straight edge? If so, just buy some more material and CAREFULLY butt up to the old material.
A couple of points here, make sure the material runs in the same direction, shine a strong light on it, or use your hand to feel the lay of the cloth, with some practice you'll feel it.
Use a good amount of glue on both sides of the join to glue material to board, but don't get any glue on the join itself, and don't press the join down hard. Let it lay a little loose, make sure it's all good then brush it down with the palm of your hand.
Regards, Andrew.
Old Nov 30, 2009 | 06:05 PM
john1990's Avatar
thanks I'll give it a try
shirley
Aug 19, 2012 01:25 AM
Tim's 88 240
Jul 7, 2011 03:00 AM
turbo940v
Feb 26, 2010 10:48 PM
Dingbat
Dec 19, 2005 10:25 PM
Oldespeed
Feb 14, 2005 11:04 PM
