Sheared wires inside headliner - please help
Old Dec 15, 2005 | 06:37 AM
Dingbat's Avatar
Default Sheared wires inside headliner - please help
I recently bought a 78' Volvo 245DL at a charity auto lot for $700, and I couldn't be happier with it. One thing I need to fix though is a set of wires that travel along the passenger side hinge for the rear hatch. They somehow got sheared off, and it would be really nice to have my rear defrost and my rear wipers working in this weather. I was planning to pull the headliner(part, or the whole thing) and simply butt connect some sutible wires on to the old ones and run them don the the wiper motor/defrost, but I started looking at how the headliner was attached and got bewildered. Its in beautiful shape right now and I would hate to ruin a good thing. Does anyone have experiance in pulling these headliners off and putting them back on? Thanks
Old Dec 16, 2005 | 08:53 PM
Default RE: Sheared wires inside headliner - please help
It has been a while but I think when you remove the moldings then you can peel it back some and remove the rods.
Old Dec 17, 2005 | 10:43 PM
Dingbat's Avatar
- What mouldings are you refering to? There seems to be a frame that goes around the top interior that the rods go into, but this whole frame is wraped by the headliner(none of the frame is exposed). The headliner appears to be held on to the outer frame with a adhesive, should I just peel the headliner off and stick it back on when I'm done? I just need to get the passenger side corner off to get to the broken wires. Thnaks for the reply
Old Dec 17, 2005 | 11:58 PM
I forget exactly. If you can wait a couple of days I will check on Monday at work.
Old Dec 19, 2005 | 10:06 PM
Dingbat's Avatar
Thanks for your help Tech, but I found my answers right here; http://www.swedishbricks.net/TechTip...teharness.html . I had the day off, so I was able to do a little research and found this article describing exactly how to fix my problem. The headliner - it just stretches off and when your done, it just goes right back on! [sm=goodidea.gif]I LOVE SWEDISH ENGINEERING!!!! Its so simple, yet so clever. Thanks again for you replies.
Old Dec 19, 2005 | 10:25 PM
Glad I helped atleast a little. LOL
allenzachary
Nov 1, 2011 10:58 AM
Volturbo
Mar 24, 2010 12:53 PM
turbo940v
Feb 26, 2010 10:48 PM
john1990
Nov 30, 2009 06:05 PM
colgate41
Oct 5, 2007 07:04 AM
