Heated Seat Wiring Available?
Old Oct 15, 2016 | 11:15 AM
smshnick's Avatar
Smile Heated Seat Wiring Available?
Hi again all,
I've recently discovered that the 240 I'm restoring had heated seats, but some owner along the way removed some of the wiring. Does anyone know where I can get the wiring? Also, I see where the wiring goes from the seat to the harness, but I don't know how the actual switches hook up or what they hook up to. Thanks for any advice and help you can offer.
Nick
Old Oct 15, 2016 | 07:29 PM
Volvodok's Avatar
Switches were/are in the hand brake console. Are the grids in the seats or is the main harness gone?
Old Oct 15, 2016 | 08:08 PM
smshnick's Avatar
I have the switches (they came in a box of parts) and there are wires under the driver and passenger seat. The passenger seat has a wire or two hanging from the bottom, though one is clipped. The driver seat didn't have any wires, though I'm about to pull the bottom seat cushion cover to see if there's a grid there or not. I assume they both have it though. I'm also unsure where those two wires go that are under the floor carpeting.
Old Oct 17, 2016 | 03:07 AM
the wiring is pretty simple...
Attached Thumbnails Heated Seat Wiring Available?-240-1992-heated-seats-1.jpg   Heated Seat Wiring Available?-240-1992-heated-seats-2.jpg
Old Oct 17, 2016 | 09:56 AM
smshnick's Avatar
Ah-hah! Those diagrams clear it up perfectly! Thanks!
Old Oct 21, 2016 | 07:40 AM
Moetheshmoe's Avatar
Would this be the same for a '91 740?
Old Oct 21, 2016 | 06:42 PM
the 740 is probably similar but no, there's significant wiring differences between the 240 and 7/9's.
I'll try and remember to dig up a 740 heated seat diagram later tonight, right now I don't have time
Old Oct 22, 2016 | 01:48 AM
1991 740/940 heated seats...
Attached Thumbnails Heated Seat Wiring Available?-740-940-1991-seat-heaters-2.jpg   Heated Seat Wiring Available?-740-940-1991-seat-heaters-1.jpg
Old Oct 22, 2016 | 05:57 PM
Oceantrucker's Avatar
I have 89 wagon and do not need heated seats here in Hawaii. Can sell you my stuff. Will have to see if it works first.
Mahalo, Annie eight 0 eight six 3 seven 5 six 8 three
Old Oct 22, 2016 | 07:18 PM
smshnick's Avatar
Nevermind, thanks! I ended up getting a kit from Wagonmeister. I was going to use the factor buttons as well, but ended up using his as they are two-stage. I simply drilled holes in the center console blanks and voila!
Old Oct 22, 2016 | 07:22 PM
smshnick's Avatar
Thumbs up Pic of the heater switch..
What do you think?
Old Oct 23, 2016 | 10:20 AM
Thanks. This helps a lot.
upperhillsdale
Jan 18, 2008 01:41 PM
spinningcain
Mar 26, 2006 03:49 AM
Enzo
Feb 15, 2006 04:59 AM
cool_kyle_3000
Jan 4, 2006 05:58 PM
tony8169
Feb 2, 2005 12:07 PM
