heater control switch broken, only cold air
Old Mar 23, 2013 | 08:51 PM
Ryan Dunham's Avatar
Default heater control switch broken, only cold air
hello again, my 1980 240dl's heater isnt working
the blower is fine and so is the heater core, its just that control switch,
you know the one that goes from cold to hot, well it was really stiff
then it broke and its stuck on cold, its not connected to anything back inside,
how do i fix this or atleast get it on heat only?
thanks!
Old Mar 24, 2013 | 08:26 AM
Default more information
i traced the cable back into the dash, and i found some pictures on another forum.
by my right foot under the panel is a mechanical lever with a spring on an assembly,
the linkage is broken somewhere up in the dash, because the lever does nothing
the slide was in the fully extended position with the spring holding it there,
i removed the tension spring, and tried to slide the slide towards me
it was stuck but after working it a bit i got it all the way towards me in the fully retracted position.
the air went from being -5c(23f) outside temp, to around 13c(55f). still very cold.
i let it run for a bit but even with the engine hot it isnt above 60,
any ideas?
Old Mar 24, 2013 | 08:47 AM
Default heater control valve
so it seems that my heater control valve is stuck close to closed
is there any way i can free it up?
Old Mar 25, 2013 | 04:04 AM
sicnarf's Avatar
Take off the panel and check it out behind the dashboard. Maybe you could be successful. or buy a new valve from the junkyard.
lamerad
Jan 24, 2022 10:39 PM
Rayanmar
2001-2013 model year V70
Oct 5, 2013 06:17 PM
mnvolvo
Mar 1, 2012 11:16 AM
snkpkp
May 13, 2009 08:52 PM
Cboms40
Jan 31, 2007 06:09 PM
