Heater Stopped Emitting Heat
Old Feb 2, 2008 | 12:02 PM
rjrcpa's Avatar
Default Heater Stopped Emitting Heat
It worked on Friday night, but is only emitting cold air this Saturday morning.
I have had the heater core replaced before. Is this a heater core issue again? Or could be a bad connection somewhere under the hood?
Old Feb 3, 2008 | 03:14 AM
jonesg's Avatar
Default RE: Heater Stopped Emitting Heat
When you move the heater controls can you hear the vacuum motors actuate?
they make a hissing noise as doors open and close.
I think the valve to actuate the heat is behind the engine on my 740.
If so I'd look for leaking vac line, unless you have water in the footwells.
One way to find it is to listen after shutting the engine down.
What model is your car?
Mick Maag
1998-2000 model year V70
Oct 8, 2012 07:43 PM
W35
Aug 12, 2009 08:22 PM
boombs
Dec 22, 2008 02:29 PM
boombs
Dec 22, 2008 10:01 AM
Squiggy
Jan 12, 2008 10:55 AM
