Hello, I am Jane from Durham, England
Old May 13, 2008 | 10:11 AM
bigbird's Avatar
Default Hello, I am Jane from Durham, England
Hello, I am Jane from Durham, in the North East of England. Hope you don't mind me joining in. I have a 1996 Volvo Estate 940 LPT. I have had it for 8 Months now, I have a problem with the oil light flashing intermittently when I brake from higher revs. No unusual engine noise, 150.000 miles on the clock. Overall well looked after. I have tried the obvious oil and oil filter change. I would be grateful for any advice Please. Thanks.
Old May 13, 2008 | 11:33 AM
S70driver's Avatar
Default RE: Hello, I am Jane from Durham, England
Welcome to the forum.
Old May 13, 2008 | 01:21 PM
bigbird's Avatar
Thank You.
Old May 13, 2008 | 01:31 PM
JPN's Avatar
JPN
Welcome to the forum, we havea great moderator from Durham as well.
It was too bad that the forum at Volvo Owner's Club U.K was shut down.
As to the problem on your Volvo, hop over to the 940 forum; I believe there are some experts there.
Best of luck & cheers,
JPN
Old May 13, 2008 | 01:39 PM
billofdurham's Avatar
Jane,
JPN,
[sm=thanx.gif]
Bill.
Old May 13, 2008 | 06:15 PM
bigbird's Avatar
Hello, Yes it is a shame about the Volvo Owners Club Forum closing down. Thanks, I will try the 940 Forum. I was reading through this forum and I found a couple of similar problems suggesting it could be water on the oil pressure switch, fingers crossed that's all thst is wrong. Thank for your help. Jane
Old May 13, 2008 | 06:17 PM
bigbird's Avatar
Thanks
Old May 14, 2008 | 10:17 AM
jks2's Avatar
Welcome Jane.
Old May 14, 2008 | 02:36 PM
bigbird's Avatar
Thanks, I have found it very interesting and helpful. [sm=mail.gif]
Old May 14, 2008 | 03:21 PM
johnpoach's Avatar
And a welcome from wales uk Jane. Enjoy. John.
Old May 14, 2008 | 04:34 PM
bigbird's Avatar
Hello, and thank You.
Old Jun 1, 2008 | 09:42 AM
65mustang's Avatar
Welcome aboard.
Old Jul 3, 2008 | 03:06 PM
bigbird's Avatar
Hello, I asked for help in June, I have a 1996 Volvo 940 LPT. The oil light on the dash was flicking on when I was slowing down. A month before this started I put the car into a garage for an oil and filter change.( Requesting a Genuine Volvo oil filter.) I checked the dip stick and the oil level appeared to be low, strange since I had recently had the oil changed at the garage, the car has never been smokey or burned oil, and has no oil leaks. I have filled the oil up, and over the last month the oil level has hardly moved. I can only assume the garage must have drained the oil out, but not filled the car up with enough oil. Needless to say I will not be using that garage anymore. Thank you for all your help and advice at the Volvo Forum. I will certainly use the forum again. Regards, Jane
Old Jul 3, 2008 | 05:25 PM
nixie's Avatar
Hi Jane, just joined my self i have a V70 2.5 20v and i live in Whitehaven, Cumbria 2 hours away
Old Jul 4, 2008 | 02:25 AM
robv70's Avatar
hi jane from a fellow newbie in northampton.
rob
Old Jul 4, 2008 | 01:25 PM
A common problem in some establishments. Usually the apprentice gets blamed for not putting enough in.
One of the first things I do when someone else has changed my oil is to pull the dipstick to see if they have put enough in. Doing this in front of the garage lets them know you won't be taken for a ride.
If you live in the Durham City area I can give you the name of a vey good independent mechanic who does all the jobs properly.
Old Jul 16, 2008 | 05:28 PM
  #17
bigbird's Avatar
Hello Nixie, Rob v70, Billofdurham and everyone, yes please Bill, I would like the name of the independent mechanic please. Many Thanks, Jane
Scuba Jim
North East
May 26, 2024 11:29 AM
bond007
Jan 26, 2011 04:05 PM
moonraker
May 10, 2007 01:46 PM
jack9139
Jul 5, 2006 12:38 PM
kipper
Feb 17, 2005 10:11 AM
