High Idle Speed - 1993 940 Regina
Old Apr 19, 2018 | 06:30 PM
drcampbell's Avatar
Default High, Erattic Idle Speed - 1993 940 Regina
Cold start: (0-10 °C) Idles at 2400 rev/minute
Warm start: Idles at 3200 rev/minute, no doubt due to the reduced engine oil viscosity.
After touching the gas pedal once, idle speed cycles between 1500 and 2000 rev/min, once every second or two. It sounds like a fuel cut upon reaching 2000 rev/min.
This anomaly began suddenly and has been consistent. The day before, the idle speed was about 800 rev/min, with slight hunting. (maybe ±150 rev/min)
Engine runs smoothly and delivers the usual amount of power. I have not driven it enough to comment on fuel consumption. I suspect it's burning a lot of fuel at red lights. I need to stand on the brakes pretty hard; it idles at 30 mi/hr if I don't.
Disconnected the battery overnight. No change.
Suspecting a stuck idle-air control valve, I disconnected the electrical connector from the IAC. Idle speed dropped to a steady 300 rev/min. (warm engine) That suggests there are no stray vacuum leaks.
Pin 1 on the IAC connector has 12 volts.
Pin 3 has ~160Ω to ground with the ignition switch on; several hundred kΩ to ground with the switch off.
(there is no pin 2)
Pin 1 to pin 3 on the IAC itself: 4Ω.
Pin 1 to the body of the IAC: ∞
The throttle-position switch clicks when the throttle is moved slightly off idle. Have not confirmed its function with an ohmmeter.
Suggestions? I'm hoping somebody out there understands this system and its software better than I do.
Automagic transmission, no turbocharger. 232,000 miles.
Driven every other day or so, entirely city driving, less than 200 miles per week.
Old Apr 19, 2018 | 07:54 PM
Moetheshmoe's Avatar
Go to this link:
https://www.volvoclub.org.uk/faq/Eng...PressureSensor
and look under "Regina Manifold Air Pressure (MAP) Sensor"
That was the culprit on my'91 740. Good news is it's available as a GM part, meaning cheap. There's also a temperature sensor in the airbox that can be faulty.
Old May 6, 2018 | 03:23 PM
drcampbell's Avatar
The saga continues:
Not the MaP sensor. Output: 4.8 volts DC when open to the atmosphere; falls toward 1 volt DC as the pressure is reduced.
Checked the tube to the MaP sensor. Despite its age, the nylon tubing looks good as new. The rubber connector is a little stiff, but doesn't appear to be cracked or leaking. Covered/sealed it with a piece of heat-shrink tubing anyway.
Unplugged the MaP sensor. No new fault code, but the engine refused to start. Reconnected it.
City fuel consumption has increased to 12 mi/gal. I haven't done enough highway driving to say what the highway mileage is.
Fault codes
2-3-3 (Adaptive idling control out of limits)
2-2-1 (Lambda sond sensor absent or faulty) and
1-2-2 (Air temperature sensor signal absent or faulty)
Replaced the O₂ sensor, which was completely covered with soot.
#4 spark plug had hard, grey, ashy/sandy deposits.
Disconnected the battery overnight. All fault codes cleared.
Ran the engine for 5-10 minutes. No change in idle behavior, no fault codes.
Unplugged the intake-air temperature sensor. Code 1-2-2, as expected. Reconnected it.
Sensor resistance: 2.6 kΩ at 15°C; 12 kΩ at -20°C.
Latest trick: it puked up 3 liters of coolant, but the temperature gauge suggested it wasn't overheating, and it didn't leak when I applied pressure with a radiator pressure tester, either cold or warm.
Old May 6, 2018 | 05:52 PM
the other three plugs looked OK (light grey coating, not oily or charcoal ?)
if one cylinder is that different than the other three, I'd be doing a compression test on all 4 cylinders before I go much farther.
Old May 6, 2018 | 06:34 PM
drcampbell's Avatar
The other three plugs were sooty, but not crusty.
Compression: 175 - 175 - 171 - 173 lbf/in˛
I figgered as much, since it runs smoothly and develops a normal amount of power when you put the pedal to the metal.
It's nice to know the long block's in good shape, even if I'm temporarily flummoxed by today's injection/ignition/emission problem.
Old May 6, 2018 | 07:06 PM
have you 'smoke tested' for intake air leaks ? various ways you can do this, but the idea is to spray something thats NOT fresh air flooding the various possible sources of vacuum leaks, like around the injectors, around the throttle body and idle air valve, etc.
Old May 7, 2018 | 04:52 PM
drcampbell's Avatar
I don't think it's a vacuum leak.
- It started doing this suddenly. One minute, it idled at 900 rev/min. The next minute, 2400 rev/min.
- When I unplug the electrical connector from the idle air control valve, it idles at 300 rev/min. If a vacuum leak were responsible for the fast idle, unplugging the IACV wouldn't have any effect.
It's not the throttle-position switch, either. It switches normally (less than 1Ω) at each end of the throttle's travel. Pin #2 is solidly grounded, (again, less than 1Ω) and pins #1 & #3 are not.
Old May 7, 2018 | 05:22 PM
ok, then its quite possible your IAC Valve is sticking open... time to pull it and clean it (throttle body spray cleaner works reasonably well on these). if the rubber hoses to it are at all sketchy, I'd plan on replacing them with fresh rubber as they are much harder to install when they are rock hard than fresh pliable rubber.
Old May 7, 2018 | 05:40 PM
drcampbell's Avatar
Originally Posted by pierce
ok, then it's quite possible your IAC Valve is sticking open ...
When I disconnect the electrical connector from the IACV, idle speed drops to a steady 300 rev/min. (warm engine) Were a stuck-open IACV responsible for the fast idle, unplugging the IACV wouldn't have any effect.
Old Jan 22, 2019 | 08:53 PM
Zem4243's Avatar
Did you ever figure this out??
Old Jan 22, 2019 | 09:34 PM
drcampbell's Avatar
Yes. It turned out to be a chafed & grounded control wire that was holding the IACV open. But only when everything was assembled. When I removed the connector from the IACV to put an ohmmeter on it, I also un-grounded the chafed wire. After I repaired the insulation, it began idling at 700 rev/min and fuel consumption dropped to the window-sticker estimate.
Never did figure out why it suddenly puked up 3 liters of coolant one day. It did that only once, then resumed its usual consumption/leakage -- about 0.05 l/month.
Old Jan 22, 2019 | 09:45 PM
Zem4243's Avatar
So look at the wires that connect to the IAC. My 93 940 is having rpm problems, where the rpms bounce from 700 to 1,000 rpms. I cannot figure out what is wrong with this damn car.
tobydell
Feb 15, 2023 09:14 PM
Cboyz
Dec 26, 2021 12:25 AM
albert89
May 21, 2015 10:20 PM
tobydell
Mar 8, 2011 07:48 AM
dobrosailor
Jan 16, 2010 10:21 PM
