Hood liner caught on fire (82 245 DL)
Old Dec 27, 2013 | 11:03 AM
Matt McDaniel's Avatar
Default Hood liner caught on fire (82 245 DL)
Hi folks,
Strange thing happened this morning - I pull into work, shut the wagon off, and white smoke begins coming out from under the hood. Panic! - but it doesn't smell like fluids burning, so a little relief there . I open the hood up, and to my surprise, there's a quarter-sized smoldering hole in the hood liner. The hole is slowly smoking away and getting bigger, so I put it out with a pair work jeans and a coworker's bottle of water. The mystery: it's not in a spot that would touch anything - it lines up diagonally between the battery and the power steering pump. Nothing else in the engine compartment looks burned or scorched, nor does anything have the toast smell, or burnt fluid smell. Any ideas?
Old Dec 27, 2013 | 02:28 PM
My best guess so far:
Cig was thrown from passing truck, hits windshield. I thought it went up, but maybe it could have gone down and under? The liner is a touch loose, maybe just enough...
Old Dec 27, 2013 | 02:46 PM
TIPSP's Avatar
Got Boost?
That is strange. I think the positive cable runs around that spot.
How's the battery cables? It could have done it.
heat from engine Could have helped ignite it.
Or open cable could have sparked from contact with hood.
I don't use the hood liners on my cars.
I will eventually get around to using the IPD heat kit.
Other might have more experience with this.
Old Dec 28, 2013 | 12:26 AM
if the battery isn't secured, and you hit a hard bump, it can fly up and hit the roof. if the positive terminal hits the roof, sparks will fly.
kpprod
Oct 21, 2014 10:45 AM
Red Tractors
Aug 20, 2013 10:33 PM
jigen3
Dec 23, 2011 06:09 PM
Swampdawg
Apr 21, 2011 07:14 AM
Swampdawg
Apr 10, 2011 10:02 PM
