Hot start problem and shaky rpm dial
Old Jul 27, 2007 | 10:32 AM
MaT3ka0rA's Avatar
Default Hot start problem and shaky rpm dial
Hello there
I'm new in this forum and I hope it isn't too bad manners to annoy you with a little problem that occurs to my 940 '95 2.0 turbo right now.
It happens that, after some time idling or driving, the car stops and makes a hell to start again. You have to wait for some time and then it starts and drives with no further problem.
During the last 3 months I've spotted that the rpm dial is a little shaky on cold starts. The needle moves with little jumps up or down. When the engine is hot this problem seems to stop.
My OBD gives all 1-1-1 codes.
I've thinked of the fuel pump relay or the rpm sensor.
Wich one is to blame in your opinion?
Many thanks and please forgive my bad english
Daniele from Italy
Old Jul 27, 2007 | 04:20 PM
wojeepster's Avatar
Default RE: Hot start problem and shaky rpm dial
I vote for the fuel pump relay.
Old Jul 27, 2007 | 04:55 PM
RKHunter's Avatar
I'd had the same symptoms with my '93 940 Turbo. Took it in to a Volvo specialist locally, and it turned out to be the Ignition Control Module. Just a tip - hope it helps.
xingchow
Jun 11, 2013 08:10 AM
Inga
Jan 26, 2012 01:46 PM
samloz
Oct 15, 2007 07:15 PM
beardo265
Sep 27, 2007 09:24 AM
