How offen do you change the timing belt
Old Aug 29, 2010 | 08:47 PM
Magic_Don's Avatar
Default How offen do you change the timing belt
I have an 1989 245 (non turbo), I notice the timing belt has 85,000 miles on it. How many miles do you go between changes?
Thanks for your input. Don
Old Aug 30, 2010 | 12:15 AM
coonmanxyz's Avatar
Check the manual but I think that you are due.
Old Aug 30, 2010 | 08:51 AM
swiftjustice44's Avatar
Can't get to my AllData right now but I'm fairly sure that the square tooth geared motors like yours have a service interval of 50k. Regardless, you are definitely due. It's customary to closely examine the belt tensioner (I always replace mine out of laziness) the crank, cam and intermediate shaft seals. They often will seep without be visible when timing cover is installed.
Old Aug 31, 2010 | 07:13 AM
act1292's Avatar
The service interval for the later models is 50K so it is well overdue. It won't hurt your engine if it breaks while you are driving but it will leave you stranded.
I agree with Swift on this one - I always replace the tensioner and the seals if I don't know the history on the car. Also, it would be good to check out the water pump while it is apart. Make sure that bearings aren't worn or loose.
nicolas414
Oct 9, 2024 12:53 PM
crayola110
Aug 10, 2012 09:44 PM
Psaboic
Oct 29, 2006 10:28 AM
thejman
Jun 9, 2006 09:45 PM
Psaboic
May 9, 2006 10:36 PM
