How to remove rear window on 1989 240 Wagon?
I have to remove the rear window and rear window gasket on my 1989 240 wagon. Does anyone know how to do this?
Do I remove the window from the gasket, then the gasket from the car?
Do I remove the window and gasket from the car together?
How do I remove them? It seems like they are in there very tight.
How do I put the window back in?
Thanks!
Thanks!
That only works if its soft rubber glue, which i'm 90% sure its not. I'm pretty sure its a fairly hard pressed in rubber with glue on it. My best guess would be to remove the trim around the window and the wiper and anything that might get in the way inside the car. Go to a corner of the window, and using a piece of bass guitar string or piano wire. Try to force it through once you do basically make a sawing motion while going around the window. I have a feeling you'll either break the widow or give up shortly after starting.
volvonomore
Jun 18, 2012 10:55 PM
