240 1993 wagon
Old Sep 7, 2009 | 02:31 PM
manwithabird's Avatar
Default 240 1993 wagon
The head lights only come on when I press the brake and the high beems don't stay on , I am on the incompetent side when it comes to electrical but I can follow instructions good any one help me out?
Old Sep 7, 2009 | 04:02 PM
blue goose's Avatar
Does the bulb failure warning light come on when you press the brakes? Or when you turn the headlights on?
Old Sep 8, 2009 | 05:48 AM
Default break lights
The bulb out light has never come on and I will start with that . I will also check if all the other lights work . Mark
Old Sep 10, 2009 | 07:08 AM
holobox's Avatar
when odd things like this arise (headlights come on when I hit the brake pedal) I'd start by looking for a loose or broken ground connection. Just to help a bit, a light bulb needs a hot wire and a ground connection in order to function. Sounds like the headlamp switch is working or you wouldn't have light under any condition. But if the ground connection for the headlamp circuit has been lifted during a recent repair or somehow is now open (broken wire in the wiring harness?) the headlamp won't light unless it can find another ground path - and that may be through the brakelamp circuit.
When you hit the brake pedal - are the headlamps at full brightness or do they seem a little dimmer than usual?
Charlie
Old Sep 11, 2009 | 04:18 PM
Thank you charlie....the brightness is full .i will look for faulty grounds.mark
jws
Dec 30, 2011 08:09 PM
Gator
Jan 20, 2009 08:21 AM
redrocket
Jan 5, 2009 04:38 AM
VolvoTeen
Aug 11, 2007 05:12 PM
JimDaddy
Jul 18, 2006 07:17 PM
