How to test RPM sensor?
Old Oct 24, 2008 | 10:24 PM
Dg90Volvo740GLE's Avatar
Default How to test RPM sensor?
1990 Volvo 740 GLE wagon. Having a 'no spark' issue. I fear the RPM sensor is the source of my problem, but I dont want to end up replacing a working one. Does anyone know how to test the RPM sensor?? Thanks in advance
Old Oct 24, 2008 | 10:27 PM
Default RE: How to test RPM sensor?
How does it look?
If the outer sheilding is cracked or falling apart replace it.
BTW I moved it to the proper section.
Old Oct 24, 2008 | 10:38 PM
I cant see the sensor itself since it is behind the motor on the bellhousing however, the 'sheilding' or foil wrapped around the outside of the 3wires coming from it is cracked and frayed. Is this what you mean?
btw what forum did you move this to? I couldnt find anything more specific than this section. I apoligize...
Old Oct 24, 2008 | 10:47 PM
If you see the foil then all the black insulation is all gone already. I would replace it and see if you have spark then.
Those wires need to be totally sealed up.
I moved it to the 240,740,940 section you had it in the V40 section.
Old Oct 24, 2008 | 10:55 PM
It looks like Ill need to pull the trans to replace it, not to mention a new one is pretty expensive. I nned to know if there is a procedure to test it while installed.I need a definitive answer as to whether it is working or not. I do haveDVM. Anyone with any info would be greatly appreciated.
Old Oct 24, 2008 | 11:08 PM
You don't need to pull the tranny only 1 screw holds it in.
Thats what you need.
http://www.fcpgroton.com/product-exe...ategory_id/116
Old Oct 24, 2008 | 11:09 PM
Also sorry I don't have the specs but if the tach doesn't move that usually means the sensor is toast.
Old Oct 24, 2008 | 11:11 PM
Thanks. That sensor is for an 8-valve engine mine is 16v, are thewy the same?
Old Oct 24, 2008 | 11:25 PM
Yes it looks like it here is the one for the 16V.
Old Oct 24, 2008 | 11:27 PM
Thanks for your help I appreciate it
Old Oct 24, 2008 | 11:31 PM
No problem anytime.
Also here is a pic looking down at the speed sensor as well from the top. To show the screw.
Old Oct 27, 2008 | 12:33 AM
fredbyte's Avatar
Go to www.stepbystepvolvo.com for free diagnostic guide for 740 no-starts. No spark has 3 main culprits: RPM sensor, Power Stage, or ignition coil.
Gullfisk
Oct 11, 2022 10:18 PM
Gullfisk
Feb 16, 2012 04:24 PM
richsid
Mar 25, 2008 01:01 PM
willko1
Dec 13, 2005 01:38 AM
