HVAC issues/questions...no defrost
Old Aug 22, 2012 | 12:41 PM
jayson44's Avatar
Default HVAC issues/questions...no defrost
ok, so this morning was the first time I've had to use my defrost since getting the car. I found out that no matter what buttons I push on my HVAC, the air only blows out of the vents and a little on my legs. the rear defrost seems to work just fine, but the front ducts don't change.
there's a slight hissing noise coming from around the HVAC controls that gets louder if I push in just the heat/feet button.
any ideas? is the HVAC run with vacuum? something just isn't changing correctly...
J.
Old Aug 22, 2012 | 07:00 PM
yup the vent controls run on vacuum. there's a vacuum line from the intake manifold that has a 1-way valve and goes through the middle of the firewall somewhere, the vent controls vary with year and model car and version of ventilation you have (ECC vs MCC on the 700/900s, etc).
lowvolts
Mar 25, 2010 08:53 PM
janeofdrama
Mar 30, 2009 10:47 PM
Maxbaby
Apr 18, 2007 03:16 AM
850forum
Feb 25, 2007 01:51 AM
Air Defender
Mar 2, 2005 02:29 PM
