Springy noise from speedometer? and rear defrost issues.
Old Feb 28, 2008 | 08:53 PM
janeofdrama's Avatar
Default Springy noise from speedometer? and rear defrost issues.
I posted earlier but no one responded and it seems to be getting worse. When I hit certain speedy, a spring noise starts occuring. I was told by a friend that it could be my speedometer, either it's going out or there is a spring in it that is messed up. My car seems to still run fine, but when I go 20, 30, etc, any speed of 10 it makes this sound. Im afraid it could be worse than just being the speedometer, but it could be the speedometer because when I turn on the rear defrost, the speedometer stops working. Any ideas, Please and Thank you!!
Old Feb 29, 2008 | 10:10 AM
jonesg's Avatar
Default RE: Springy noise from speedometer? and rear defrost issues.
I'm not a mechanic but I would try a couple of things to try track it down,
disconnect the speedo and see if the noise stops.
If the speedo is electroniclike mine it has a sensor at the rear axle.
Theres a plug connector near the rear axle.
Read the FAQ file on speedos.
http://www.brickboard.com/FAQ/700-90...ClusterRemoval
I don't know about the rear defroster, its must be on the same circuit as the speedo, have you checked fuses etc? Some of the speedos ( a lot of em) have suspect gears in them and require aftmkt replacement gears, its just a small plastic gear. I bought aused speedo on ebay and swapped it out.
If you have a 940 wagon the wiring harness in the door hinge often fails.
Old Mar 30, 2009 | 10:47 PM
superbeetlejosh's Avatar
My odometer made a scratchy noise. You could tell it was the odo because the noise occurred every time the trip meter moved. I took the cluster apart and found the little electric actuator that moves the odometer. I greased it and it fixed the problem. Hope this helps.
-josh
evanernest
Feb 4, 2015 12:16 PM
jayson44
Aug 22, 2012 07:00 PM
Matt Lagusis
Apr 19, 2012 11:04 AM
mattdp79
Apr 16, 2008 06:56 PM
960Tuck
Nov 14, 2006 04:14 PM
