Hydraulic trunk assist problem
Old Jan 2, 2005 | 05:01 PM
740TurboGuy's Avatar
Default Hydraulic trunk assist problem
Shut the trunk the other day on something that evidently jammed up the right hydraulic arm thing and when the trunk approached closing level I heard a rush of air/fluid (there was some brownish wet stuff at the arm). Now the trunk is dead weight and won't stay up.
Anyone know how I deal with this and specifically where to get a used part? Get a new arm? I am using a prop in the meantime.
Thanks!
Old Jan 2, 2005 | 09:09 PM
Default RE: Hydraulic trunk assist problem
You should replace both the trunk shocks.If you have a PEP Boys in your area they arent that bad for then new there.You should buy new if you buy used they might go out in a week.
Old Jan 2, 2005 | 11:08 PM
Excellent, thanks! I def need to replace - the wood chock is getting old.
Old Jan 2, 2005 | 11:24 PM
lol I hear you on that one.
pptmmt
Jul 29, 2013 09:00 AM
Vincef
Mar 18, 2009 08:42 PM
ko_kidd
Aug 10, 2006 10:49 PM
