IAC sensor eary 88 240
Old Jan 9, 2022 | 04:27 PM
Zombi's Avatar
Default IAC sensor eary 88 240
I know the iac sensor, that is the sensor mounted in the block below the temperature gauge sensor in the head is broken. All the part number pictures seem to have a two prong sensor. I have an early88 car.
I have a one prong sensor. Got a correct part number, or was this car Mcgivered?
Old Jan 9, 2022 | 05:04 PM
The broken sensor in the block is the early style knock sensor. 1317296. If you trace that wire back it goes to the ignition control unit The two sensors in the head - the singe wire one in the front is for the gauge the other one in the back of the head is for the fuel injection system. What problem are you trying to solve?
Old Jan 9, 2022 | 07:33 PM
Zombi's Avatar
I had a temp gauge problem that turned out to be the board. Got it working.
What makes this thing priced like platinum? It's just a piezo electric current generating device. Thanks for your rapid reply.
Old Jan 9, 2022 | 08:07 PM
If the car runs fine leave it alone. Why is it $$ - maybe supply and demand? Last year used was ~1988
Old Jan 9, 2022 | 10:06 PM
Zombi's Avatar
The Pezio electric knock sensor under severe load conditions would generate a current that in the end would retard the spark?
As the great and oft quoted philosopher Popeye once said "Leave well enough alone".
Thanks for the input.
Old Jan 10, 2022 | 07:59 AM
act1292's Avatar
Well - without the knock sensor your timing will not be correct. I don't know if the ECU automatically retards the timing if the sensor is missing so as to not damage your engine (seems like the logical thing to do). If that's the case then the only symptom will be poorer mileage and performance.
Old Jan 10, 2022 | 08:57 AM
Zombi's Avatar
A little chilly today 28F with a wind chill to go junk yarding. Good point on the default.
I just got the car a month ago and am having to go thru a bunch of hack repairs,non repairs, and bungles. No idea what the mpg is. Just bought my first full tank of gas.
One problem with estate cars is that sometimes the little old lady was getting taken to the cleaners by her mechanics. Filthy no name filters, dirty flame trap. Yucky brake fluid.
Dunlin1
Volvo XC40
Aug 24, 2021 03:54 PM
91shelby
Nov 3, 2010 12:33 AM
rfa803
Aug 2, 2010 10:40 AM
Mabel
Dec 24, 2008 05:32 PM
daver80
May 13, 2008 08:20 AM
