Idle drop/engine shudder at stops? '87 740 Turbo
Old Jul 14, 2007 | 03:22 PM
mill_farm's Avatar
Default Idle drop/engine shudder at stops? '87 740 Turbo
Any ideas for me? 1987 740T
At stops, every 5 to 10 secs the idle drops way down causing the
engine to shudder, then the idle corrects. Engine does not stall.
Runs fine when moving and no problems when in Park/Neutral.
Seemsworse when the engine is hotor when the AC is running.
Have cleaned the TB and replaced the FPR recently.
I welcome and apprecaite any suggestions.
Old Jul 15, 2007 | 10:02 AM
JAKESTERS's Avatar
Default RE: Idle drop/engine shudder at stops? '87 740 Turbo
Did you clean air flow valve? Is there black soot and smell of very rich fuel from car at idle?
Old Jul 15, 2007 | 12:07 PM
mill_farm's Avatar
Have not cleaned the air flow valve. I will consult Haynes for some guidance there. Any tips on that?
Emphatic YES on the fuel rich smell. Have not noticed soot, but will have another look.
Cheers.
Old Jul 15, 2007 | 08:26 PM
Boricuaguy18's Avatar
also can be a leak in emissons system or a bad part in the system
Old Jul 16, 2007 | 01:29 AM
Beardog's Avatar
try cleaning the Idle air control valve. It helped with mine. Then go and clean the MAF and then clean the throttle body. If these three things dont fix the problem then look to the the fuel sensor relay thats with the fuses.
Old Jul 16, 2007 | 07:18 AM
mikkowus's Avatar
When you open windows and such, do the revs drop? if so, it might be something eletrical.
Old Jul 17, 2007 | 10:35 AM
mill_farm's Avatar
I pulled off the ACV and a teaspoon or so of clean oil (?) dripped out.
Not sure if that's a sypmtom of another problem.
Used a littlecarb cleaner on the valve,the pins and the connector-which was gunked.
Results? So far so good . . . no idle drop,things have smoothed.
After a nice long freeway drive, I'll see ifsymptoms resurface.
Cheers.
Old Jul 24, 2007 | 01:19 PM
mill_farm's Avatar
I'm still having problems (must have been the placebo effect.)
I am thinking it is temperature related, since it begins only after I've been on the road a while.
There is a strong fuel odor when the idle is struggling.
To properly clean the ACV, do I need to remove the cap and clean the contacts inside?
Old Jul 26, 2007 | 03:01 PM
Kruspe31's Avatar
how are the spark plugs and the 02?
Old Jul 27, 2007 | 08:48 PM
Beardog's Avatar
dont forget the flame suspression devise, aka the pcv valve on other cars
steff503
Apr 29, 2015 10:56 AM
BPodobnik
Aug 17, 2014 04:31 PM
guest01
Apr 13, 2011 02:06 PM
dako
Nov 10, 2003 01:49 PM
