idle issue after a tune up
Old Mar 3, 2019 | 11:30 AM
bigarms24's Avatar
Default idle issue after a tune up
After I did a tune up yesterday cap rotor plugs wires all factory parts and a new air filter and upon first fire the idle is going up and down before becoming normal again
Old Mar 3, 2019 | 12:23 PM
well, your idle speed is managed by the idle air controller, which is a sort of shuttle-valve that lets controlled amounts of air bypass the throttle. if the IAC get sticky, you can get erratic idle speeds. on an 88, the engine speed is determined from the hall sensor that feeds the ignition system, the ignition system passes along a cleaned up version of the RPM signal to the ECU, and the ECU monitors the throttle position switch, when it sees the throttle is at idle, it watches the RPM and adds air via the idle air valve to keep it at a steady speed.
Ross Miner
Apr 1, 2019 10:19 AM
CA1985-245DL
May 2, 2016 06:55 PM
redstapler95
Dec 24, 2013 01:58 PM
Michael Moser
Oct 21, 2012 10:39 PM
mpower916
Oct 1, 2012 08:30 PM
