idle stinks
Old May 13, 2006 | 09:32 PM
driftin V's Avatar
Default idle stinks
i have a 91 740 gl. in good weather it runs fine, but throw in cold or especially rain and it wont idle for crap. I can put the car in neutral and keep it running by reving it up, then puting it into gear and giving it some gas to get going. but even once im moving, if i floor it, it goes really sluggish. iv replaced my air idle valve. could it be the maf? or a vacume leak? why does it run good with the warm, dry weather?
Old May 14, 2006 | 01:12 AM
Default RE: idle stinks
Have you cleaned the throttle body?
Yes it could be the Mass flow sensor.
Old May 15, 2006 | 07:22 PM
wojeepster's Avatar
Also check the accordian looking hose for holes. Unmetered air will make it run bad. It rubs against the fender and get a hole worn in it usually.
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
chocobello
Oct 26, 2008 09:05 AM
