Idling 240 very loud and shakes
Old Feb 10, 2018 | 12:07 PM
tbuchan's Avatar
Default Idling 240 very loud and shakes
Hello my 1993 240 at idle seems to now shake and rattle more than ever before. I've read that it could need a Throttle Body cleaning?
Any other recommendations? Is throttle body cleaning a DIY?
Any information would be great.
Thanks
Trevor
Old Feb 10, 2018 | 02:25 PM
TnBob's Avatar
Id start with a good injector cleaning.
Sounds like a good basic tuneup is in order too
Old Feb 10, 2018 | 03:09 PM
when was the ignition system last R&R'd (new plugs, rotor, distributor cap, and if needed, spark plug wires?)
does the engine hold a steady idle once warmed up? with your foot on the brake, if you shift from P or N to D or R, do the RPMs stay fairly constant after a brief dip, or does it lug and stumble when stopped in gear ?
idle problems can be caused by the throttle position idle switch not being properly adjusted, a gummed up throttle body not fully closing, a gummed up idle air control valve, or random vacuum leaks. see https://www.volvoclub.org.uk/faq/Eng...#Idle_Problems for a variety of tests and such.
also, it might be the engine mounts (and the transmission mount, which is in effect the third engine mount). these are 25+ year old cars, those mounts are rubber and rot with age and oil spills.
naelec
Mar 11, 2013 03:20 PM
CyDetrakD
Feb 22, 2011 05:08 AM
keaunym
Nov 17, 2010 12:55 PM
nicolaselias
Sep 18, 2009 08:51 PM
Steady
Aug 8, 2008 11:11 PM
