ignition ECU
Old Oct 4, 2009 | 08:46 PM
fredbyte's Avatar
Default ignition ECU
Hello Everybody,
Have a no-start on a 1987 740 turbo, LH-Jetronic 2.2, B230 FT. No spark. Narrowed it down to Power Stage and its feed. Got 0.12 VDC between pin 5 & ground for the Power Stage feed at ignition "Start," with R/W wire at #1 and blue wire at #15 on ignition coil terminals disconnected. Proper voltage is 2 VDC.
Seems to me that it may be an ignition ECU problem. Any other tests I should run? What are your opinions?
Also, if I need to replace an ignition ECU, who can you recommend? Seems like brand new IECUs are out of sight---over $1000. Any remanufacturers with a stellar reputation?
Thanks.
Old Oct 5, 2009 | 10:22 PM
tedv's Avatar
I'd get a used ECU from the junkyard, probably $20 from a U-Pull-It type. Hell, get a couple of them--should last long enough.
VolvoBug
Oct 13, 2014 02:44 PM
makaveli2k
Aug 8, 2012 12:32 PM
matt01
Jul 23, 2012 11:12 AM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
