sunroof crank/seal questions
Old Oct 4, 2009 | 04:55 PM
90240DLGA's Avatar
Default sunroof crank/seal questions
I'm having a real problem keeping the crank handle assembly tightened. After a period of use(over a period of weeks) the crank assembly will loosen causing the worm gear to slip and chatter. I'm afraid that this will cause undue wear on the worm/drive gear and was wondering if anyone has any tricks or repair advice on how to provide a long term fix for this?
Also, does anyone know if the seal for the sunroof is available anywhere? Mine is original and appears to have an outer fabric cover with a soft metallic inner structure. The fabric on mine has disintegrated and the internal metal is showing through in places. It's rather unsightly and I would like to replace it if possible.
Old Oct 5, 2009 | 10:35 PM
tedv's Avatar
Sounds like something is stripped or may be the screws you have there are not the right size. The seal is still available new, or try getting a used from a junkyard, U-Pull-It type is the best for those kind of parts.
ZaphodBblbrux
Jul 2, 2012 09:54 PM
Lavid2002
May 26, 2011 06:00 AM
Lavid2002
Mar 1, 2011 06:20 PM
datderboy216
May 22, 2010 06:38 PM
rpsail7cs
Sep 25, 2009 09:12 AM
