initial startup misfire, does anyone know?
Old Jul 18, 2007 | 09:59 PM
dtupac's Avatar
Default initial startup misfire, does anyone know?
Problem, 89 240 dl, every start after it has sat for a while is misfiring for about 10 seconds or until i rev up to about 2k. Does anyone here have or had this problem. I am kind of thinking it might be the coil since its original, or possible a vacuum leak or gasket. any info would be appreciated thanks otherwise it will be the usual no response, seems nobody on here helps anyone
Old Jul 18, 2007 | 10:18 PM
dtupac's Avatar
Default RE: initial startup misfire
oh, and to answer the question, plugs, wires, rotor, dist cap have been replaced, cleaned throttle body that's why i'm thinking coil. if i was almost 20 years old on this car i'd probably misfire too.
Old Jul 22, 2007 | 10:41 AM
outofworkjoe's Avatar
wires cross,loose coil wires.How does it ilde?
Old Jul 22, 2007 | 12:26 PM
dtupac's Avatar
it idles good, just recently started a couple weeks ago and only an initial 5-10 second misfire that cancels out when i raise the rpm
Old Jul 22, 2007 | 05:47 PM
Kruspe31's Avatar
I had a coil problem that did the same thing. Also had a loose exhaust mainfold bolt that was loose, but that was a big shake
jelarf
Jan 27, 2021 03:43 PM
pjfslk
Jan 29, 2007 12:25 AM
cool_kyle_3000
Jul 16, 2006 03:15 AM
gordon368
Apr 9, 2006 03:34 PM
