Issues with in-tank pump, but problem remains after replacement
Old 07-16-2022, 06:49 PM
gdaley's Avatar
Default Seven years too late but…
Originally Posted by xq244+245
Thank you Pierce and Act1292 for your helpful comments. The MAF replacement was done only because of the hesitation when gong uphill above 2000-2250 rpm...I thought that because the MAF controls the air/throttle it might be a factor when the engine is under load (besides, I just paid $17.50 for the MAF including shipping, and replaced it in less than 10 min). I have thought that perhaps the pump--Bosch and all-is noisy and also certainly about the issue with the deposits on the tank having to slowly be pushed through the fuel pump, filter, etc. It's just the fact that the three factors (noisy pump all the time, hesitation only under high load and hesitation under high load only when the tank is less than half full) are combined and still present after replacing so many things that bugs me and my curiosity....
  • The thing about the #11 fuse immediately reminded me of an ’88 Saab 900 issue that stumped me for a year. Ran perfectly for about 30-60 sec on cold start then barely. On the umpteenth diagnostic foray I unplugged the O2 sensor and it ran perfectly. The heater circuit was shorted in the sensor allowing the 12v dc signal to reach the ECU. The intersection of that with your post is that the fuse that powers the pre-pump on my early 90’s 940s that have one also powers the O2 sensor heater circuit.
rphud
09-27-2014 06:06 PM
xevo
02-26-2012 07:25 AM
bobbie
02-18-2011 06:19 PM
AnEskimo
10-07-2010 07:28 AM
Quick Reply: Issues with in-tank pump, but problem remains after replacement
