Tank leaking after new fuel pump
Old Feb 17, 2011 | 01:04 AM
bobbie's Avatar
Default Tank leaking after new fuel pump
Hi Guys,
Replaced the fuel pump on my daughter's 1998 S70. I have petrol spewing out of the connection that contains the non return valve on the filler pipe to the tank. Obviously too much pressure build up. Does anyone know if this might be a normal occurrence and if so, what is the best approach to fixing it.
Also, should I have also replaced the fuel filter?
Cheers
Rob
Old Feb 17, 2011 | 01:08 PM
Did you install the filter backwards?
Old Feb 17, 2011 | 02:49 PM
bobbie's Avatar
Hi rspi,
I haven't changed the filter. It wasn't due. Someone said that I should put one in with the new pump. Could the filter be blocked? The car is running OK. There was two pipe connections to the pump housing. I think the other might be a breather. Though why would that pack up now?
I am a bit perplexed as to why the tank is pressurising.
Cheers
Old Feb 17, 2011 | 04:15 PM
bobbie's Avatar
Got it fixed! Looks like I did not press the fittings to the fuel pump assembly down far enough. These fittings must have a valve in them. When I released them and re installed them they went right down to the housing. Quite a critical fit. I had to turn the pump assembly a few degrees so that the fittings were DIRECTLY square with the pipe to the pump before they would go on smoothly!
Another lesson learned.
Cheers
Old Feb 18, 2011 | 10:47 AM
Hey Bobbie: Thanks for the update. We appreciate the followup.
Old Feb 18, 2011 | 06:19 PM
bobbie's Avatar
hi guys, had a whim from a member having difficulty removing the pipes to the fuel pump. I gave him this advice if anyone else has difficulty removing them.
A special tool is generally required , which has a "V" notch in the end of a flat tool about 3/4 inch wide and turned up at the end about 30 degrees.
I bought 2 cheap screwdrivers and bent the ends up about half an inch - 13 mm - on both screwdrivers. Place the screwdrivers on either side of the fitting to the fuel pump assembly and gently but firmly prise upwards. There is a quick release on the fitting. The fitting will "pop" up. You will read the problem I had reconnecting these. They have to be very straight/aligned with the pipes on the fuel pump assembly.
Hope this is helpful to another in the future
Cheers
dwwhite
1998-2000 model year V70
Aug 24, 2020 09:46 AM
rphud
Sep 27, 2014 06:06 PM
AnEskimo
Oct 7, 2010 07:28 AM
tobolate
Jan 12, 2010 10:46 PM
skyrider20
Nov 29, 2008 07:01 PM
