Leaking Rear Freeze Plugs
Old Jan 19, 2015 | 06:42 PM
Consigliere's Avatar
Default Leaking Rear Freeze Plugs
Hi All,
Newbie here! '94 940 wagon non-turbo 232.000 miles. Runs well, no oil consumption, etc.
The car has developed a fairly severe coolant leak/drip from the rear of the engine. No external leaks at the water pump or head gasket. Thought maybe transfer pipe, heater control valve or related hoses.
Today, I got the care up on a lift and was able to do a thorough examination of those items and found them all to be dry. The coolant was clearly dripping from the bell housing. I assume there are freeze plug(s) in the rear of the block and wondering if one of those could be the source of the leak.
Anyone have any experience with these freeze plugs leaking and, if so, replacement of same? Engine out, transmission out, etc?
All suggestions appreciated.
Thanks.
Old Jan 19, 2015 | 06:47 PM
Default Rear Freeze Plugs Leaking
Hi All,
Thanks.
Old Jan 19, 2015 | 08:55 PM
Welcome to the Forum.
My suggestion is if you have a problem with your car post the question under your cars section as you're much more likely to get another owner who knows what you are talking about than posting it in "New Member".
Moved to 940
Old Jan 20, 2015 | 01:54 AM
the freeze plugs are on the side of the block. but they rarely fail.
Heater hoses are far more likely, that or a coolant seepage out a soon-to-be-blown head gasket below exhaust ports 3-4. my 92 had a plastic heater valve ('chevy style') that failed and wasn't obvious at all.
a coolant system pressure test would verify the heater hoses are good, and probably let you track the leak down.
SurfSled240
Jan 5, 2013 12:35 PM
GaryBrad
Jan 10, 2010 12:04 AM
tr_car_nut
Aug 26, 2009 07:15 PM
yellow95
Apr 22, 2006 12:42 AM
ctierney
Dec 29, 2004 04:23 PM
